Inleiding
Use this guide if you would like to replace the CMOS battery of your HP Envy 17-3070NR. The CMOS battery ensures that you BIOS setting are saved when your PC is on. It also runs the clock, making sure you have correct time when you power you computer back on. These batteries tend to last 10 year but should it fail earlier, use this guide to replace it.
Wat je nodig hebt
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Één andere persoon heeft deze handleiding voltooid.
