Ga door naar hoofdinhoud
HP Envy 15-u001dx Wireless Network Card Replacement
Wat je nodig hebt
  1. HP Envy 15-u001dx Wireless Network Card Replacement, HP Envy 15-u001dx Disassembly: stap 1, afbeelding 1 van 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Wireless Network Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Wireless Network Card Replacement: stap 3, afbeelding 1 van 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Wireless Network Card Replacement: stap 4, afbeelding 1 van 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Wireless Network Card Replacement: stap 5, afbeelding 1 van 2 HP Envy 15-u001dx Wireless Network Card Replacement: stap 5, afbeelding 2 van 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Wireless Network Card Replacement, Wireless Network Card: stap 6, afbeelding 1 van 1
    • Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
  7. HP Envy 15-u001dx Wireless Network Card Replacement: stap 7, afbeelding 1 van 1
    • Use the spudger to remove the antenna connector attached to the black wire labeled "1".
  8. HP Envy 15-u001dx Wireless Network Card Replacement: stap 8, afbeelding 1 van 1
    • Detach the antenna connector for the white wire labeled "2".
  9. HP Envy 15-u001dx Wireless Network Card Replacement: stap 9, afbeelding 1 van 1
    • Gently remove the card from its slot by pulling.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dakota Presley
885 Reputatie
6 handleidingen geschreven
USF Tampa, Team 9-4, Lacy Fall 2016 Lid van USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 625
