Ga door naar hoofdinhoud
HP Envy 15-u001dx Cooling Fan Replacement
Wat je nodig hebt
  1. HP Envy 15-u001dx Cooling Fan Replacement, HP Envy 15-u001dx Disassembly: stap 1, afbeelding 1 van 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Cooling Fan Replacement: stap 5, afbeelding 1 van 2 HP Envy 15-u001dx Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: stap 6, afbeelding 1 van 2 HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: stap 6, afbeelding 2 van 2
    • Remove the three 4.5 mm Phillips #0 screws holding the fan in place.
  7. HP Envy 15-u001dx Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Gently detach the connector with a spudger and the fan is free to be removed.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dakota Presley
885 Reputatie
6 handleidingen geschreven
USF Tampa, Team 9-4, Lacy Fall 2016 Lid van USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,347
