Ga door naar hoofdinhoud
HP Elitebook x360 1040 G5 Screen display Replacement
Wat je nodig hebt
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: stap 1, afbeelding 1 van 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: stap 1, afbeelding 2 van 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: stap 1, afbeelding 3 van 3
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: stap 2, afbeelding 1 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 2, afbeelding 2 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 2, afbeelding 3 van 3
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: stap 3, afbeelding 1 van 2 HP Elitebook x360 1040 G5 Screen display Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: stap 4, afbeelding 1 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 4, afbeelding 2 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 4, afbeelding 3 van 3
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: stap 5, afbeelding 1 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 5, afbeelding 2 van 3 HP Elitebook x360 1040 G5 Screen display Replacement: stap 5, afbeelding 3 van 3
    • Remove the screen from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler A Cobb
321 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G1, Hovde Fall 2019 Lid van IUPUI, Team S1-G1, Hovde Fall 2019
IUPUI-HOVDE-F19S1G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 54
Altijd: 1,871
