Ga door naar hoofdinhoud
HP Elitebook x360 1030 G2 Battery Replacement
Wat je nodig hebt
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: stap 2, afbeelding 1 van 2 HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: stap 2, afbeelding 2 van 2
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
40.298 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.199 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 163
Altijd: 4,008
