Ga door naar hoofdinhoud
HP Elitebook 8570w Optical Drive Replacement
Wat je nodig hebt
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: stap 4, afbeelding 1 van 2 HP Elitebook 8570w Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
Conclusie
MJ Routh
465 Reputatie
3 handleidingen geschreven
Baylor, Team S8-G5, Johnson Fall 2017 Lid van Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 1,796
