Ga door naar hoofdinhoud
HP Elitebook 8570w Hard Drive Replacement
Wat je nodig hebt
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • The hard drive can now be replaced inside the caddy.
Conclusie
5 andere personen hebben deze handleiding voltooid.
MJ Routh
465 Reputatie
3 handleidingen geschreven
Baylor, Team S8-G5, Johnson Fall 2017 Lid van Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 52
Altijd: 14,446
