Ga door naar hoofdinhoud
HP Elitebook 8460p RAM (Random Access Memory) Replacement
Wat je nodig hebt
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: stap 4, afbeelding 1 van 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): stap 5, afbeelding 1 van 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): stap 5, afbeelding 2 van 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): stap 5, afbeelding 3 van 3
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: stap 6, afbeelding 1 van 2 HP Elitebook 8460p RAM (Random Access Memory) Replacement: stap 6, afbeelding 2 van 2
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Great job thanks
Charles Tighe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 1,978
