Ga door naar hoofdinhoud
HP Elitebook 8460p Optical Drive Replacement
Wat je nodig hebt
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: stap 5, afbeelding 1 van 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: stap 5, afbeelding 2 van 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: stap 5, afbeelding 3 van 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: stap 6, afbeelding 1 van 2 HP Elitebook 8460p Optical Drive Replacement: stap 6, afbeelding 2 van 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: stap 7, afbeelding 1 van 3 HP Elitebook 8460p Optical Drive Replacement: stap 7, afbeelding 2 van 3 HP Elitebook 8460p Optical Drive Replacement: stap 7, afbeelding 3 van 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: stap 8, afbeelding 1 van 3 HP Elitebook 8460p Optical Drive Replacement: stap 8, afbeelding 2 van 3 HP Elitebook 8460p Optical Drive Replacement: stap 8, afbeelding 3 van 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 17
Altijd: 1,033
