Ga door naar hoofdinhoud
HP Elitebook 8460p Modem Card Replacement
Wat je nodig hebt
  1. HP Elitebook 8460p Modem Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: stap 4, afbeelding 1 van 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: stap 5, afbeelding 1 van 2 HP Elitebook 8460p Modem Card Replacement, Modem Card: stap 5, afbeelding 2 van 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: stap 6, afbeelding 1 van 2 HP Elitebook 8460p Modem Card Replacement: stap 6, afbeelding 2 van 2
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: stap 7, afbeelding 1 van 2 HP Elitebook 8460p Modem Card Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,561
