Ga door naar hoofdinhoud
HP Elitebook 820 G1 RAM Replacement
Wat je nodig hebt
  1. HP Elitebook 820 G1 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: stap 3, afbeelding 1 van 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: stap 5, afbeelding 1 van 1
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Conclusie
Ashley Francavilla
103 Reputatie
1 Handleiding geschreven
USF Tampa, Team S5-G1, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,142
