Ga door naar hoofdinhoud
HP Elitebook 820 G1 Keyboard Replacement
Wat je nodig hebt
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: stap 7, afbeelding 1 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 7, afbeelding 2 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: stap 9, afbeelding 1 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 9, afbeelding 2 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: stap 10, afbeelding 1 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 10, afbeelding 2 van 3 HP Elitebook 820 G1 Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the keyboard from the housing.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Lauren Vance
388 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G2, Harley Fall 2018 Lid van IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
2 Leden
4 handleidingen geschreven
Één opmerking
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 11,021
