Ga door naar hoofdinhoud
HP Elitebook 820 G1 Fan Replacement
Wat je nodig hebt
  1. HP Elitebook 820 G1 Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Fan Replacement: stap 3, afbeelding 1 van 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Fan Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Fan Replacement: stap 6, afbeelding 1 van 1
    • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
    • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
  7. HP Elitebook 820 G1 Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
    • Remove SD card cap by just sliding out to reveal one screw.
  8. HP Elitebook 820 G1 Fan Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
    • Remove the 4mm SD card screw using the J00 tip.
  9. HP Elitebook 820 G1 Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the one 4mm fan screw using the J00 tip screwdriver.
    • Remove screw and metal plate to expose ribbon cable connector.
  10. HP Elitebook 820 G1 Fan Replacement: stap 10, afbeelding 1 van 1
    • Use an opening tool to pry up the ribbon connector to disconnect.
  11. HP Elitebook 820 G1 Fan Replacement: stap 11, afbeelding 1 van 1
    • Turn laptop over back to normal position as shown in the image.
    • Use opening tools to pry up keyboard.
    • When prying up keyboard, be sure to start near any corner of the keyboard.
    • There are two ribbon cables that must be disconnected before fully removing keyboard.
  12. HP Elitebook 820 G1 Fan Replacement: stap 12, afbeelding 1 van 3 HP Elitebook 820 G1 Fan Replacement: stap 12, afbeelding 2 van 3 HP Elitebook 820 G1 Fan Replacement: stap 12, afbeelding 3 van 3
    • Carefully lift keyboard on one side to expose the two ribbon cables.
    • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
  13. HP Elitebook 820 G1 Fan Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
  14. HP Elitebook 820 G1 Fan Replacement: stap 14, afbeelding 1 van 3 HP Elitebook 820 G1 Fan Replacement: stap 14, afbeelding 2 van 3 HP Elitebook 820 G1 Fan Replacement: stap 14, afbeelding 3 van 3
    • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
    • The display is connected to the shell of the laptop.
  15. HP Elitebook 820 G1 Fan Replacement: stap 15, afbeelding 1 van 1
    • Unplug fan cable by pulling away from its connector.
  16. HP Elitebook 820 G1 Fan Replacement: stap 16, afbeelding 1 van 1
    • Unscrew the two 6mm fan screws using the J00 tip.
    • Fan screws are encased in springs and cannot be removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
[deleted]
217 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 69
Altijd: 8,436
