Ga door naar hoofdinhoud
HP Elitebook 6930p CPU Replacement
Wat je nodig hebt
  1. HP Elitebook 6930p CPU Replacement, Take off the Heatsink: stap 1, afbeelding 1 van 1
    • Unscrew the screws in order from left to right in the picture.
    • Insert wisdom here.
  2. HP Elitebook 6930p CPU Replacement, Unplug the fan: stap 3, afbeelding 1 van 1
    • Do this step if the cord of the fan is in the way of the CPU.
    • Make sure the new CPU works or is better than the old one if you are upgrading the CPU.
Conclusie
To reassemble your device, follow steps 1-4 in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Lowell
156 Reputatie
2 handleidingen geschreven
Één opmerking
I have try to install both types T9900 and T9800 both CPU’s were not working at all. Bios F20 and operating System Win 7 32Bit.
it crashes already by try to access the bios
Maybe any sugestion about that?
moonlights - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 3,771
