Ga door naar hoofdinhoud
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Wat je nodig hebt
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: stap 1, afbeelding 1 van 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: stap 1, afbeelding 2 van 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: stap 1, afbeelding 3 van 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: stap 2, afbeelding 1 van 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: stap 2, afbeelding 2 van 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: stap 2, afbeelding 3 van 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: stap 3, afbeelding 1 van 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: stap 3, afbeelding 2 van 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyle Koivuniemi
605 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-24, Maness Fall 2015 Lid van Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Leden
14 handleidingen geschreven
2 opmerkingen
where can i buy a replace cage for the hard drive?
Thomas Dickson - Antwoord
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 85
Altijd: 8,421
