Ga door naar hoofdinhoud
HP EliteOne 800 G1 Fan Assembly Replacement
Wat je nodig hebt
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 3 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: stap 1, afbeelding 2 van 3 HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: stap 1, afbeelding 3 van 3
      • Place computer with the screen down on a flat surface.
      • Push the two locking latches to the unlocked position.
      • Push the cover toward the top of the computer and lift up.
      Vraag FixBot
      Voeg opmerking toe
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: stap 2, afbeelding 1 van 2 HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: stap 2, afbeelding 2 van 2
      • Press locking latch on the bottom of the base of the stand.
      • Pull the plastic cover off of the stand.
      Vraag FixBot
      Voeg opmerking toe
    2. HP EliteOne 800 G1 Fan Assembly Replacement: stap 3, afbeelding 1 van 2 HP EliteOne 800 G1 Fan Assembly Replacement: stap 3, afbeelding 2 van 2
      • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
      • Tilt stand and lift up to remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. HP EliteOne 800 G1 Fan Assembly Replacement: stap 4, afbeelding 1 van 2 HP EliteOne 800 G1 Fan Assembly Replacement: stap 4, afbeelding 2 van 2
      • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
      • Pull the back panel toward the bottom of the device to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Fan Assembly: stap 5, afbeelding 1 van 1
      • Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
      Vraag FixBot
      Voeg opmerking toe
    2. HP EliteOne 800 G1 Fan Assembly Replacement: stap 6, afbeelding 1 van 2 HP EliteOne 800 G1 Fan Assembly Replacement: stap 6, afbeelding 2 van 2
      • Use a Torx T15 driver to remove the three 6mm screws surrounding the fan assembly.
      • Pull the fan assembly up from the case to remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Michael Ewing
1.071 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-24, Maness Fall 2015 Lid van Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 7,466
