Ga door naar hoofdinhoud
HP EliteBook x360 830 G6 Motherboard Replacement
Wat je nodig hebt
  1. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the back cover: stap 1, afbeelding 1 van 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Motherboard Replacement, Release the clips: stap 2, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement, Release the clips: stap 2, afbeelding 2 van 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Motherboard Replacement, Release the remaining clips: stap 3, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement, Release the remaining clips: stap 3, afbeelding 2 van 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: stap 4, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: stap 4, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the back cover: stap 4, afbeelding 3 van 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: stap 5, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: stap 5, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the battery: stap 5, afbeelding 3 van 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the battery: stap 6, afbeelding 1 van 1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: stap 7, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: stap 7, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the battery: stap 7, afbeelding 3 van 3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
  8. HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: stap 8, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: stap 8, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Disconnect the SSD cover: stap 8, afbeelding 3 van 3
    • With your spudger, pry up on the tabs at the top and bottom of the SSD cover.
    • This will loosen the SSD cover enough for it to pop out from its tension clips.
  9. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD cover: stap 9, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD cover: stap 9, afbeelding 2 van 2
    • Lift the SSD cover off the SSD and remove it.
  10. HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the SSD: stap 10, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement, Unfasten the SSD: stap 10, afbeelding 2 van 2
    • Use your Phillips screwdriver to remove the 2.4 mm-long screw from the SSD.
  11. HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: stap 11, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: stap 11, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Remove the SSD: stap 11, afbeelding 3 van 3
    • Grip the edges if the SSD near the screw indent.
    • Pull the SSD straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
  12. HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: stap 12, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: stap 12, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, CMOS Battery: stap 12, afbeelding 3 van 3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  13. HP EliteBook x360 830 G6 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
  14. HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: stap 14, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: stap 14, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Cooling System: stap 14, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  15. HP EliteBook x360 830 G6 Motherboard Replacement: stap 15, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement: stap 15, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement: stap 15, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  16. HP EliteBook x360 830 G6 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Separate the fan and cooling system from the motherboard.
  17. HP EliteBook x360 830 G6 Motherboard Replacement, Wi-Fi Card: stap 17, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement, Wi-Fi Card: stap 17, afbeelding 2 van 2
    Koop
    • Remove the two antenna cable with tweezers.
    • The blue tagged antenna will be on the left side. The red tagged antenna will be on the right side.
  18. HP EliteBook x360 830 G6 Motherboard Replacement: stap 18, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the 3 mm screw securing the Wi-Fi card.
    • The card will pop up at a slight angle once the screw is removed.
  19. HP EliteBook x360 830 G6 Motherboard Replacement: stap 19, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Grasp the sides of the Wi-Fi card to slide it out of the socket to remove.
    • Gently remove the Wi-Fi card. There is risk of damage to the socket if removed forcefully.
  20. HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: stap 20, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: stap 20, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement, Motherboard: stap 20, afbeelding 3 van 3
    • Remove each no-fuss ribbon connector by gently pulling the blue tab straight away from the port with your fingers.
    • To disconnect the ZIF connectors, use the tip of your fingernail to flip up the small locking flap. Then disconnect the ribbon cables.
    • Grab the black plastic loop of each of the connectors pull it upwards away from the motherboard.
    • When pulling out the ribbon, do not pull up and away from the laptop. Doing so may damage the ribbon or socket.
  21. HP EliteBook x360 830 G6 Motherboard Replacement: stap 21, afbeelding 1 van 3 HP EliteBook x360 830 G6 Motherboard Replacement: stap 21, afbeelding 2 van 3 HP EliteBook x360 830 G6 Motherboard Replacement: stap 21, afbeelding 3 van 3
    • Remove the metal shield that covers the RAM module.
    • Gently pull the two silver retaining arms apart until the module flips up a few millimeters.
    • Remove the RAM module.
    • Pull the memory card straight back out of its slot to avoid damage to either part.
  22. HP EliteBook x360 830 G6 Motherboard Replacement: stap 22, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the five 4.1 mm screws from the plastic bracket.
    • Remove the bracket.
  23. HP EliteBook x360 830 G6 Motherboard Replacement: stap 23, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 23, afbeelding 2 van 2
    • Push in then remove the SD card slot from the side of the laptop.
  24. HP EliteBook x360 830 G6 Motherboard Replacement: stap 24, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Remove the remaining cords connecting to the motherboard near the top.
  25. HP EliteBook x360 830 G6 Motherboard Replacement: stap 25, afbeelding 1 van 2 HP EliteBook x360 830 G6 Motherboard Replacement: stap 25, afbeelding 2 van 2
    • Gently lift and remove the motherboard.
    • Do not tug or forcefully pull the motherboard to remove it. If there is any significant resistance, double check that all previous steps were completed and all accessories are removed.
Conclusie
Brody Reder
301 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-3, Harley Spring 2024 Lid van IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 26
Altijd: 51
