Ga door naar hoofdinhoud
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Wat je nodig hebt
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: stap 2, afbeelding 1 van 2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: stap 2, afbeelding 2 van 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: stap 3, afbeelding 1 van 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: stap 4, afbeelding 1 van 1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: stap 5, afbeelding 1 van 1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: stap 6, afbeelding 1 van 1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Conclusie
Ashia Lewis
246 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 551
