Ga door naar hoofdinhoud
HP EliteBook x360 1030 G3 Solid State Drive Replacement
Wat je nodig hebt
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: stap 2, afbeelding 1 van 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: stap 3, afbeelding 1 van 2 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: stap 3, afbeelding 2 van 2
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: stap 5, afbeelding 1 van 1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Pablo Arriola
504 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G9, Maness Spring 2019 Lid van Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Leden
16 handleidingen geschreven
3 opmerkingen
Which SSD is compatible with this computer?
Trinayaan Hariharan - Antwoord
Very nice its clear
Fuad Gugsa - Antwoord
J'ai un problème de son
Sallpape - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 126
Altijd: 5,909
