Inleiding
This guide explains how to remove the bottom cover on the underside of the laptop.
Wat je nodig hebt
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
