Ga door naar hoofdinhoud
HP EliteBook x360 1030 G3 Bottom Cover Replacement
Wat je nodig hebt
  1. HP EliteBook x360 1030 G3 Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Bottom Cover Replacement: stap 2, afbeelding 1 van 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
Conclusie
Shea Charkowsky
786 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G9, Maness Spring 2019 Lid van Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 116
Altijd: 5,667
