Inleiding
Is your HP EliteBook Folio 1020 G1 speaker not working? If so, here is a guide to fix the problem by replacing the faulty speaker.
Before taking any part of the computer apart, please remember to power down your computer and unplug the power cable from any power source. Failure to do so could harm yourself or the computer, so these precautions must be taken.
Wat je nodig hebt
Stap 1 Lower Case
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
