Inleiding
A hard drive is a storage unit for computers, and there are two different types of hard drives HDD and SSD. HDDs are traditional storage devices with spinning platters that read and write data, and SSDs are newer technology that stores data on instantly accessible memory chips.
The HP EliteBook 8470p has a few different options for hard drive: 320/500/750GB 7200 rpm SMART SATA II or 500GB 7200 rpm SMART SATA II self encrypting drive. The EliteBook 8470p does have other storage options like a HP 3D DriveGuard (windows only), which the hard drive is mounted directly to the notebook frame, or a Solid State Drive, which can come as a; SATA 6Gb/s 128GB Solid State, or SATA 6 Gb/s 256 GB SED Solid State.
The HP EliteBook 8470p is roughly a decade old laptop, in order to keep up with the increasing programs and storage required to run these programs, the hard drive will need to be upgraded. This guide will help show how to replace the current hard drive.
Wat je nodig hebt
Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
With the laptop latch still facing away from you, slide the left release latch to the left.
Één andere persoon heeft deze handleiding voltooid.
