Ga door naar hoofdinhoud
HP EliteBook 840 G5 Battery Replacement
Wat je nodig hebt
  1. HP EliteBook 840 G5 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 HP EliteBook 840 G5 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 Battery Replacement: stap 2, afbeelding 1 van 3 HP EliteBook 840 G5 Battery Replacement: stap 2, afbeelding 2 van 3 HP EliteBook 840 G5 Battery Replacement: stap 2, afbeelding 3 van 3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 Battery Replacement: stap 3, afbeelding 1 van 1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the 4mm screws that are fastened on the battery with your T9 Torx screwdriver.
  5. HP EliteBook 840 G5 Battery Replacement: stap 5, afbeelding 1 van 2 HP EliteBook 840 G5 Battery Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the power supply connector by tugging it from the sides of its head.
    • Make sure not to pull on the wires, as they could become damaged.
  6. HP EliteBook 840 G5 Battery Replacement: stap 6, afbeelding 1 van 1
    • Slide the battery out and remove it from the device.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Ryan McMullen
608 Reputatie
3 handleidingen geschreven
Cal Poly, Team S25-G13, Maness Spring 2018 Lid van Cal Poly, Team S25-G13, Maness Spring 2018
CPSU-MANESS-S18S25G13
4 Leden
18 handleidingen geschreven
6 opmerkingen
The battery shown in the photo is a TT03XL. My HP Elitebook 840 G5 laptop has a SS03XL battery. Before you order your replacement battery, take off the laptop’s bottom cover and confirm the battery model you need.
manuelw - Antwoord
Unfortunately, the TR9 Torx Security Screwdriver did not work on my Elitebook 840 G5. It is unclear if this is due to the battery model. Mine is a SS03XL battery.
Sarah Macrina - Antwoord
Same problem, i ordered battery based on this, but this model have SS03XL battery un TT03XL battery is for Hp EliteBook 850 G5 G6, ZBook 15U G5 G6 Series
latvietis75 - Antwoord
I also got caught up in this battery fiasco.
Azrtheal - Antwoord
Replaced the battery with the correct SS03XL battery sold from here and have had zero luck in getting it to charge. Updated bios, firmware, everything under the sun, drained the system of residual power. Disconnected CMOS battery because I'm reaching for anything at this point. Bios diag options doesn't even list battery diag as an option. Battery is not detected. I'm at a loss, help pls.
Daniel A. Barcenas Jr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 44
Afgelopen 7 dagen: 268
Afgelopen 30 dagen: 1,100
Altijd: 79,701
