Ga door naar hoofdinhoud
HP EliteBook 755 G5 Battery Replacement
Wat je nodig hebt
    • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: stap 2, afbeelding 1 van 2 HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: stap 2, afbeelding 2 van 2
    • Turn the computer upside down on a flat surface.
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
    • Starting under the middle of the display, pry and lift the bottom cover off the computer.
  2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: stap 4, afbeelding 1 van 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
40.307 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.303 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 50
Altijd: 1,090
