Ga door naar hoofdinhoud
HP EliteBook 745 G4 Battery Replacement
Wat je nodig hebt
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: stap 2, afbeelding 1 van 1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: stap 3, afbeelding 1 van 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: stap 3, afbeelding 2 van 2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: stap 4, afbeelding 1 van 1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: stap 5, afbeelding 1 van 1
    • Loosen the two captive screws and remove the battery from the computer
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Max Kletskov
40.307 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.457 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 45
Altijd: 1,203
