Inleiding
This guide will assist you in replacing the speakers on your HP EliteBook 1050 G1. If there is a change in quality of sound or possibly no sound at all coming from the speakers on your laptop then this guide will be useful for you.
For this replacement guide you will need a Phillips #00 Screwdriver, iFixit opening tool, Spudger, and the TR9 Torx Security Screwdriver.
Wat je nodig hebt
Close your laptop and turn it over so that the side without the HP logo is facing you.
Using the TR9 screwdriver, loosen the nine screws from the base of the device.
Use the spudger to wiggle out the speaker cable. Make sure to apply moderate pressure on the sides as this will make it easier for the speaker cable to come out.
