Ga door naar hoofdinhoud
HP EliteBook 1040 G4 Speakers Replacement
Wat je nodig hebt
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: stap 2, afbeelding 1 van 2 HP EliteBook 1040 G4 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: stap 4, afbeelding 1 van 2 HP EliteBook 1040 G4 Speakers Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: stap 5, afbeelding 1 van 2 HP EliteBook 1040 G4 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: stap 6, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: stap 8, afbeelding 1 van 1
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove the speakers from the device.
Conclusie
Hannah DiMartino
395 Reputatie
3 handleidingen geschreven
Clemson, Team 4-1, Hunter Fall 2021 Lid van Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 484
