Ga door naar hoofdinhoud
HP EliteBook 1040 G4 Coin Cell Battery Replacement
Wat je nodig hebt
  1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 2, afbeelding 1 van 2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 2, afbeelding 2 van 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 4, afbeelding 1 van 2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 5, afbeelding 1 van 2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 5, afbeelding 2 van 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Coin Cell Battery: stap 6, afbeelding 1 van 1
    • Carefully disconnect the pin connector from the right side of the speaker assembly.
  7. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 7, afbeelding 1 van 2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 6 mm black screws securing the speakers to the device.
    • Lift the speakers up and out.
  8. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 8, afbeelding 1 van 1
    • Carefully disconnect the coin cell battery cable located under the motherboard.
  9. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: stap 9, afbeelding 1 van 1
    • Remove the coin cell battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 469
