Ga door naar hoofdinhoud
HP Elite x2 G1 1012 Front Facing Camera Replacement
Wat je nodig hebt
  1. HP Elite x2 G1 1012 Front Facing Camera Replacement, Display: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 4, afbeelding 1 van 2 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 5, afbeelding 1 van 3 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 5, afbeelding 2 van 3 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 6, afbeelding 1 van 2 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 Front Facing Camera Replacement, Front Facing Camera: stap 7, afbeelding 1 van 2 HP Elite x2 G1 1012 Front Facing Camera Replacement, Front Facing Camera: stap 7, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the screw.
  8. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Use the spudger to gently lift up the camera.
  9. HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 9, afbeelding 1 van 2 HP Elite x2 G1 1012 Front Facing Camera Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to disconnect the flex cable from the motherboard.
    • Remove the front-facing camera from the device.
Conclusie
Colin Mika
943 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G7, Maness Spring 2018 Lid van Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 648
