Ga door naar hoofdinhoud
HP Elite x2 G1 1012 Display Replacement
Wat je nodig hebt
  1. HP Elite x2 G1 1012 Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: stap 2, afbeelding 1 van 2 HP Elite x2 G1 1012 Display Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: stap 3, afbeelding 1 van 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: stap 4, afbeelding 1 van 2 HP Elite x2 G1 1012 Display Replacement: stap 4, afbeelding 2 van 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: stap 5, afbeelding 1 van 3 HP Elite x2 G1 1012 Display Replacement: stap 5, afbeelding 2 van 3 HP Elite x2 G1 1012 Display Replacement: stap 5, afbeelding 3 van 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: stap 6, afbeelding 1 van 2 HP Elite x2 G1 1012 Display Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Colin Mika
943 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G7, Maness Spring 2018 Lid van Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 3,344
