Ga door naar hoofdinhoud
HP Elite x2 1012 G2 SSD Replacement
Wat je nodig hebt
  1. HP Elite x2 1012 G2 SSD Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 SSD Replacement: stap 2, afbeelding 1 van 3 HP Elite x2 1012 G2 SSD Replacement: stap 2, afbeelding 2 van 3 HP Elite x2 1012 G2 SSD Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 SSD Replacement: stap 3, afbeelding 1 van 2 HP Elite x2 1012 G2 SSD Replacement: stap 3, afbeelding 2 van 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 SSD Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 SSD Replacement: stap 5, afbeelding 1 van 3 HP Elite x2 1012 G2 SSD Replacement: stap 5, afbeelding 2 van 3 HP Elite x2 1012 G2 SSD Replacement: stap 5, afbeelding 3 van 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 SSD Replacement: stap 6, afbeelding 1 van 2 HP Elite x2 1012 G2 SSD Replacement: stap 6, afbeelding 2 van 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 SSD Replacement, SSD: stap 7, afbeelding 1 van 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 SSD Replacement: stap 8, afbeelding 1 van 2 HP Elite x2 1012 G2 SSD Replacement: stap 8, afbeelding 2 van 2
    • Remove the single Phillips M2.0x2.0 screw on the SSD using a Phillips screwdriver. Turn the screwdriver counterclockwise to remove the screw.
  9. HP Elite x2 1012 G2 SSD Replacement: stap 9, afbeelding 1 van 2 HP Elite x2 1012 G2 SSD Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the SSD to the left and up to remove it from the device.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Hunter Lane
277 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G5, Livingston Spring 2018 Lid van Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Leden
13 handleidingen geschreven
2 opmerkingen
Vielen Dank für die sehr gute Anleitung. Es hat alles perfekt geklappt.
Das Display selber sitzt zum Teil aber sehr fest im Gehäuse und man muss sich überwinden etwas Kraft anzuwenden.
Sollte man zu fest ziehen (und einem das Display entgegenspringt) besteht ja die Gefahr die filigranen Kabel abzureißen.
Andreas Gerl - Antwoord
Mein Lüfter läuft ständig. Sollte die Wärmeleitpaste eingetrocknet sein?
Der Experte - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 268
Altijd: 20,019
