Ga door naar hoofdinhoud
HP Elite x2 1012 G2 Rear Facing Camera Replacement
Wat je nodig hebt
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 2, afbeelding 1 van 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 2, afbeelding 2 van 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 3, afbeelding 1 van 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 5, afbeelding 1 van 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 5, afbeelding 2 van 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 6, afbeelding 1 van 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: stap 7, afbeelding 1 van 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: stap 7, afbeelding 2 van 2
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 8, afbeelding 1 van 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: stap 8, afbeelding 2 van 2
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
Conclusie
WesleyEagleson
431 Reputatie
3 handleidingen geschreven
IUPUI, Team S13-G13, Wilson Spring 2019 Lid van IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 527
