Ga door naar hoofdinhoud
HP Elite x2 1012 G2 Cooling Fan Replacement
Wat je nodig hebt
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 2, afbeelding 1 van 3 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 2, afbeelding 2 van 3 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 3, afbeelding 1 van 2 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 5, afbeelding 1 van 3 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 5, afbeelding 2 van 3 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 6, afbeelding 1 van 2 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: stap 7, afbeelding 1 van 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 8, afbeelding 1 van 2 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 8, afbeelding 2 van 2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 9, afbeelding 1 van 2 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 9, afbeelding 2 van 2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 10, afbeelding 1 van 1
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: stap 11, afbeelding 1 van 1
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 12, afbeelding 1 van 2 HP Elite x2 1012 G2 Cooling Fan Replacement: stap 12, afbeelding 2 van 2
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 13, afbeelding 1 van 1
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 14, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 15, afbeelding 1 van 1
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: stap 16, afbeelding 1 van 1
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
Conclusie
WesleyEagleson
431 Reputatie
3 handleidingen geschreven
IUPUI, Team S13-G13, Wilson Spring 2019 Lid van IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 55
Altijd: 2,379
