Ga door naar hoofdinhoud
HP Elite X2 1013 G3 Battery Replacement
Wat je nodig hebt
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: stap 1, afbeelding 1 van 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: stap 2, afbeelding 1 van 2 HP Elite X2 1013 G3 Battery Replacement: stap 2, afbeelding 2 van 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: stap 3, afbeelding 1 van 2 HP Elite X2 1013 G3 Battery Replacement: stap 3, afbeelding 2 van 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: stap 4, afbeelding 1 van 2 HP Elite X2 1013 G3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery out of the housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Asmita Sharma
186 Reputatie
1 Handleiding geschreven
Cal Poly, Team S9-G12, Maness Spring 2019 Lid van Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 2,585
