Ga door naar hoofdinhoud
HP ENVY 5530 Front Panel Replacement
Wat je nodig hebt
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: stap 2, afbeelding 1 van 3 HP ENVY 5530 Front Panel Replacement: stap 2, afbeelding 2 van 3 HP ENVY 5530 Front Panel Replacement: stap 2, afbeelding 3 van 3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: stap 3, afbeelding 1 van 2 HP ENVY 5530 Front Panel Replacement: stap 3, afbeelding 2 van 2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
Conclusie
Elizabeth Surface
1.465 Reputatie
9 handleidingen geschreven
USF Tampa, Team 4-6, Meier Fall 2015 Lid van USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Leden
18 handleidingen geschreven
4 opmerkingen
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Antwoord
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Antwoord
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Antwoord
Where does the cable go?
Victorian Lover - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 2,033
