Inleiding
If there are communication problems between the computer and printer, replacing the motherboard is an option to consider in order to fix this problem. The motherboard controls all operations and functions of the printer enabling it to run properly and communicate with the computer.
Wat je nodig hebt
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
7 andere personen hebben deze handleiding voltooid.
3 opmerkingen
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
ou est localiser le sensor encoder module cb781-8006 merci
ou est installer le sensor encoder CB781-8006 Merci
