Inleiding
If there are communication problems between the computer and printer, replacing the motherboard is an option to consider in order to fix this problem. The motherboard controls all operations and functions of the printer enabling it to run properly and communicate with the computer.
Onderdelen
Geen onderdelen nodig.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  6. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  7. The mother board is located at the back of the printer. The mother board is located at the back of the printer.
    • The mother board is located at the back of the printer.
  8. Take note of the wire's location and orientation as this will be important to properly reassemble your device. Remove all of the wires connected to the mother board. There are seven in total. Remove all of the wires connected to the mother board. There are seven in total.
    • Take note of the wire's location and orientation as this will be important to properly reassemble your device.
    • Remove all of the wires connected to the mother board. There are seven in total.
  9. Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
    • Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
  10. At this point, the mother board should be free of all connections from the rest of the printer.
    • At this point, the mother board should be free of all connections from the rest of the printer.
    • Remove and replace the mother board with the new one.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Allen Bailey
185 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-35, Regan Winter 2013 Lid van Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Leden
8 handleidingen geschreven
Één commentaar
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
Ken Craven - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 8
Afgelopen 30 Dagen: 42
Altijd: 2,666
