Inleiding
This guide will replace the springs located on the sides of the metal frame that holds the ink carriage. These springs provide stability to the metal rod that supports the ink cartridge carriage.
Onderdelen
Geen onderdelen nodig.
  1. Remove the back two 14.0 mm Torx #10 screws.
    • Remove the back two 14.0 mm Torx #10 screws.
  2. Lay the printer on its back.
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. Open the frontal access panel by lifting it from the top.
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. Take out the two frontal 14.0 mm Torx #10 screws. Carefully lift the frontal cover. Don't lift it up aggressively. A strip will be attached to it.
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  6. Remove the five 13.0 mm Torx #10 screws found on top of the frame. Remove the four 9.0 mm Torx #10 smaller screws.
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  7. Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer. Now detach the white strip and wires by gently lifting them up.
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  8. Locate the springs. They will be on the side of the metal frame. Using the tweezers, grab the loop of the spring that is connected to the bar.
    • Locate the springs. They will be on the side of the metal frame.
    • Using the tweezers, grab the loop of the spring that is connected to the bar.
    • Remove the spring by lifting the loop.
Conclusie
Justin Taiki Fukada
798 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-41, Maness Winter 2014 Lid van Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 13
Altijd: 821
