Ga door naar hoofdinhoud
HP Deskjet D1660 Gear Guard Replacement
Wat je nodig hebt
  1. HP Deskjet D1660 Gear Guard Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Gear Guard Replacement: stap 2, afbeelding 1 van 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Gear Guard Replacement: stap 3, afbeelding 1 van 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Gear Guard Replacement: stap 4, afbeelding 1 van 3 HP Deskjet D1660 Gear Guard Replacement: stap 4, afbeelding 2 van 3 HP Deskjet D1660 Gear Guard Replacement: stap 4, afbeelding 3 van 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: stap 5, afbeelding 1 van 2 HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: stap 5, afbeelding 2 van 2
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Gear Guard Replacement: stap 6, afbeelding 1 van 2 HP Deskjet D1660 Gear Guard Replacement: stap 6, afbeelding 2 van 2
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  7. HP Deskjet D1660 Gear Guard Replacement, Gear Guard: stap 7, afbeelding 1 van 1
    • The gear guard will be located on the left side of the printer.
    • Grab the plastic guard and lift it up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Taiki Fukada
891 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-41, Maness Winter 2014 Lid van Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,169
