Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unplug all cords from the printer, and remove all the paper from the tray.
Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
Gently pry the scanner bed cover slightly off of the printer at the hinge.
Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
Set the printer body aside.
Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
Één andere persoon heeft deze handleiding voltooid.
