Ga door naar hoofdinhoud
HP Deskjet 2624 Scanner Glass Replacement
Wat je nodig hebt
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: stap 1, afbeelding 1 van 1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: stap 2, afbeelding 1 van 2 HP Deskjet 2624 Scanner Glass Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: stap 3, afbeelding 1 van 1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: stap 4, afbeelding 1 van 1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: stap 5, afbeelding 1 van 3 HP Deskjet 2624 Scanner Glass Replacement: stap 5, afbeelding 2 van 3 HP Deskjet 2624 Scanner Glass Replacement: stap 5, afbeelding 3 van 3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: stap 6, afbeelding 1 van 2 HP Deskjet 2624 Scanner Glass Replacement: stap 6, afbeelding 2 van 2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 37
Altijd: 728
