Ga door naar hoofdinhoud
HP Deskjet 2624 Motherboard Replacement
Wat je nodig hebt
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Deskjet 2624 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Deskjet 2624 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 490
