Ga door naar hoofdinhoud
HP Deskjet 2624 Magnetic Strip Replacement
Wat je nodig hebt
  1. HP Deskjet 2624 Magnetic Strip Replacement, Magnetic Strip: stap 1, afbeelding 1 van 1
    • Unplug the printer and remove all paper from the input tray.
  2. HP Deskjet 2624 Magnetic Strip Replacement: stap 2, afbeelding 1 van 2 HP Deskjet 2624 Magnetic Strip Replacement: stap 2, afbeelding 2 van 2
    • Using the Torx T5 screwdriver, remove the four screws holding the scanner bed module to the printer base.
    • Slowly lift up the scanner bed slightly off the base.
    • Be sure to unplug the ribbons connecting the two parts by pulling them straight out of their plugs gently.
  3. HP Deskjet 2624 Magnetic Strip Replacement: stap 3, afbeelding 1 van 2 HP Deskjet 2624 Magnetic Strip Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Magnetic Strip Replacement: stap 4, afbeelding 1 van 3 HP Deskjet 2624 Magnetic Strip Replacement: stap 4, afbeelding 2 van 3 HP Deskjet 2624 Magnetic Strip Replacement: stap 4, afbeelding 3 van 3
    • Locate the magnetic strip found running straight through the ink cartridge carriage.
  5. HP Deskjet 2624 Magnetic Strip Replacement: stap 5, afbeelding 1 van 3 HP Deskjet 2624 Magnetic Strip Replacement: stap 5, afbeelding 2 van 3 HP Deskjet 2624 Magnetic Strip Replacement: stap 5, afbeelding 3 van 3
    • To remove the strip, start by applying pressure to the silver connection located on the right hand side of the strip.
    • While applying pressure to the right hand side, push the strip off the left hand hook and pull it straight up.
    • Lift the strip vertically and unhook it from the silver strip.
    • When putting the strip back in, ensure that the arrow on the replacement faces to the right and downwards.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 457
