Ga door naar hoofdinhoud
HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: stap 1, afbeelding 1 van 1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: stap 2, afbeelding 1 van 3 HP Deskjet 2624 Ink Cartridges Replacement: stap 2, afbeelding 2 van 3 HP Deskjet 2624 Ink Cartridges Replacement: stap 2, afbeelding 3 van 3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: stap 3, afbeelding 1 van 3 HP Deskjet 2624 Ink Cartridges Replacement: stap 3, afbeelding 2 van 3 HP Deskjet 2624 Ink Cartridges Replacement: stap 3, afbeelding 3 van 3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
Conclusie
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 1,142
