Ga door naar hoofdinhoud
HP Deskjet 1055 Scanner Glass Pane Replacement
Wat je nodig hebt
  1. HP Deskjet 1055 Scanner Glass Pane Replacement, Scanner Glass Pane: stap 1, afbeelding 1 van 1
    • Take all paper out of the paper tray. Unplug the printer.
    • Remove the plastic printer-control panel on the top left.
    • Then, forcefully lift up the bottom of the panel while applying downward pressure with your thumb-as shown.
  2. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 2, afbeelding 1 van 2 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 2, afbeelding 2 van 2
    • With your other hand, slide the top of the panel towards the back of the printer.
    • Do not rip the white cable that connects the panel with the main body of the printer.
    • Disconnect the ribbon by pinching the blue tab and pulling away from the green circuit board.
    • Lift the panel free and set to the side.
  3. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 3, afbeelding 1 van 1
    • Place the plastic opening tool between the plastic cover and the mount on the printer.
    • Pry the plastic cover towards the center of the printer.
    • Pull up on the cover to remove it from the printer-as shown.
    • Repeat the process on the other side.
  4. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 4, afbeelding 1 van 1
    • To remove the glass panel, take out the four 14 mm (1/2 inch) screws with a T10 Torx screwdriver.
    • Don't lift the glass panel completely off because there are cables plugged into the underside.
  5. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 5, afbeelding 1 van 3 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 5, afbeelding 2 van 3 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the white cables from the green motherboard by pinching the cable where it connects to the green motherboard. Pull up, lightly.
    • Set the lower part of the printer aside.
  6. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 6, afbeelding 1 van 2 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 6, afbeelding 2 van 2
    • Place the glass panel, face down, on a smooth surface.
    • Remove the 14 mm (1/2 in.) screw from the white plastic tab on the side of the panel with a T10 Torx screwdriver.
  7. HP Deskjet 1055 Scanner Glass Pane Replacement: stap 7, afbeelding 1 van 3 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 7, afbeelding 2 van 3 HP Deskjet 1055 Scanner Glass Pane Replacement: stap 7, afbeelding 3 van 3
    • Remove the glass pane by carefully bending the plastic frame down from the side and sliding the glass pane out from the side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Samuel Isbell
10 Reputatie
1 Handleiding geschreven
Cal Poly, Team 9-18, Amido Fall 2012 Lid van Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 56
Altijd: 3,978
