Ga door naar hoofdinhoud
HP Deskjet 1055 Power and Various Buttons Replacement
Wat je nodig hebt
  1. HP Deskjet 1055 Power and Various Buttons Replacement, Power and Various Buttons: stap 1, afbeelding 1 van 1
    • Press your thumb down on the center of the button plate located on the left side of the printer.
    • Hook your fingers underneath the front edge of the button plate and pull upwards making sure to keep pressure on the middle of the plate with your thumb.
    • When pulling up the front cover make sure to keep your thumb pressed firmly on the cover plate and bend up the front. Not doing so will result in breaking the tab that holds the back of the plate to the printer.
  2. HP Deskjet 1055 Power and Various Buttons Replacement: stap 2, afbeelding 1 van 3 HP Deskjet 1055 Power and Various Buttons Replacement: stap 2, afbeelding 2 van 3 HP Deskjet 1055 Power and Various Buttons Replacement: stap 2, afbeelding 3 van 3
    • Once the front of the plate is loose, lift it up a few inches making sure to hold the back (paper feeding side) of the plate down.
    • Slide the plate towards the back of the printer and then lift up on the back of the plate.
    • The plate should now be disconnected from the tabs on the printer.
  3. HP Deskjet 1055 Power and Various Buttons Replacement: stap 3, afbeelding 1 van 3 HP Deskjet 1055 Power and Various Buttons Replacement: stap 3, afbeelding 2 van 3 HP Deskjet 1055 Power and Various Buttons Replacement: stap 3, afbeelding 3 van 3
    • Turn the plate over to reveal the white strip of connecting tape that connects the plate to the printer.
    • Find where the tape is connected to the green button circuit board (Location circled in red)
    • Place two fingers on the tape right where it connects to the plate and gently pull the tape out of the circuit board.
  4. HP Deskjet 1055 Power and Various Buttons Replacement: stap 4, afbeelding 1 van 1
    • Place the plate down on a flat surface with the button circuit board facing up.
    • Remove the three(3) T-10 Torx Screws from the circuit board.
  5. HP Deskjet 1055 Power and Various Buttons Replacement: stap 5, afbeelding 1 van 1
    • Lift the button circuit board up and off of the button plate.
    • To install a new button plate follow these directions in reverse order.
Conclusie
Matt
88 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-18, Amido Fall 2012 Lid van Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,750
