Ga door naar hoofdinhoud
HP Deskjet 1055 Motherboard Replacement
Wat je nodig hebt
  1. HP Deskjet 1055 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 HP Deskjet 1055 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 HP Deskjet 1055 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Turn off the printer then open the top lid in order to see the inside of the printer.
    • Wait at least 15 minutes after turning off the printer before handling the motherboard.
    • After waiting 15 minutes, locate the blue tabs and gently pull them out of their sockets.
  2. HP Deskjet 1055 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Locate the three white plugs with wires attached to them. Gently grab the sides of the white chorded plugs and pull them out of their socket.
  3. HP Deskjet 1055 Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Deskjet 1055 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using a T-10 Torx screwdriver, unscrew the three 1/2'' screws on the motherboard.
    • Note which screws were taken out of their specific spot because they must me placed back to their original spot.
  4. HP Deskjet 1055 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully pull the motherboard out of the printer.
Conclusie
In order to reassemble your device, follow these instructions in reverse orders
7 andere personen hebben deze handleiding voltooid.
Daniel
314 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-18, Amido Fall 2012 Lid van Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Leden
10 handleidingen geschreven
Één opmerking
How to open Top part
sunny.2600 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 5,243
