Ga door naar hoofdinhoud
Inleiding
Install the ink cartridge(s) when the printer runs out of ink or when the ink warning lights flash to prevent running out.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. Turn on the printer by pressing the power button.
    • Turn on the printer by pressing the power button.
  2. Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down. Pull down on the tab that lies in the middle of the newly-exposed gray cover.
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. Take the replacement cartridge out of its packaging and pull off the plastic tab. Do not touch the electrical contacts or ink nozzles.  Touching may cause malfunctions. Hold the cartridge on both sides with the title sticker facing upwards.
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. Slide the cartridge directly into open slot (tri-color on the left, black on the right). Push it forward until you hear it snap.
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. Close the gray access door.
    • Close the gray access door.
  7. Wait 30 seconds for the alignment page to print. Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. Press the color copy button to begin scan.
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
Conclusie
When the power button stops blinking, your can now use your printer.
4 andere personen hebben deze handleiding voltooid.
Daniel
293 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-18, Amido Fall 2012 Lid van Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 42
Altijd: 13,128
