Ga door naar hoofdinhoud
HP Deskjet 1000 J110a Parts Replacement
Wat je nodig hebt
  1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: stap 1, afbeelding 1 van 3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: stap 1, afbeelding 2 van 3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: stap 1, afbeelding 3 van 3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a  Parts Replacement: stap 2, afbeelding 1 van 3 HP Deskjet 1000 J110a  Parts Replacement: stap 2, afbeelding 2 van 3 HP Deskjet 1000 J110a  Parts Replacement: stap 2, afbeelding 3 van 3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a  Parts Replacement: stap 3, afbeelding 1 van 1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Conclusie
Colin Tourjee
632 Reputatie
4 handleidingen geschreven
USF Tampa, Team S5-G3, Passmore Spring 2018 Lid van USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Leden
12 handleidingen geschreven
2 opmerkingen
Very intuitive, good instructions. Highly recommended.
Krzysztof Białkowski - Antwoord
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
karenliller@comcast.net - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 947
